Brick stone help
  • Brick stone help
    Hi all,
    I have been trying to find something similar to this stone wall texture for long time but without any luck .
    Image from The Boundary studio and I am not sure if this just normal modeling or it use VrayDisplacement ?
    I was thinking of modeling 10-15 brick and use it in Railclone ,But I don;t know if that the most efficient way to do it ?
    Any help would be highly appreciated
    Thanks,
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
    Arroway has it, I think.
    https://www.arroway-textures.ch/
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Thanks Booby
      Unfortunately I couldn't find what I want there too .
      I'm afraid I will have to model it by hand, unless someone come up with a better solution ?!
        Railclone would be a good option.
        you can either model and texture parts as normal.
        though i think photogrammetry would work as well, if you could find a similar wall. then slice it up into a few different bricks. then array them around with railclone.
          looks easy to model
          use one of those rock generators on maxscript
          or the stone wall tools
            photogrammetry looks interesting I will see if I can give it a try.. thanks
              Originally posted by squintnic View Post
              looks easy to model
              mmm not sure if rock generator could help here, but I will give it a try. thanks !
                You might be able to use these with some photoshopping.
                http://www.textures.com/download/3dscans0056/127571
                http://www.textures.com/download/3dscans0058/127590
                Or use this script and make a few blocks and distribute with Railclone or something: http://www.evermotion.org/articles/s...3ds-max-plugin
                A.
                www.digitaltwins.be
                  Thanks man !
                  The first one works perfectly
                  And thanks for everyone too
                  Regards,
