vray nightly removes the normalmap from max?
  • vray nightly removes the normalmap from max?
    I have installed the latest nightly build of vray and and have made some tests, then for production I have installed the official build again, AND I miss the default normalmap of 3ds max!!!!!
    is it a vray related problem from the uninstaller or what happened?
    do I get the default map back someways?
    because I use berconmaps a lot and it crashes max if you want to make a bump with a vraynormalmap inside of a bercontile map.
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    Can you get me a scene for that so that we can fix it? Either attach it here or send it to vlado@chaosgroup.com
    Other than that, turn on the "Show incompatible" option in the material browser and it will show up.
