Hi all
Can somebody lend a hand please.
I want to have a dialog that prompts the user to browse for files, then it will add those files to a listbox. They can add to this list after the initial browse.
FOr example, the user will browse to "w:\work\" and select 2 or 3 files from there and add it to the list. Then they will also browse to a UNC path for example "\\server\stuff" and select files from here.
The files from the 1st browse together with the files from the 2nd browse should be displayd in a list. When "selection" is done. All those files from drive paths as well as UNC path, should all be copied to a single location.
I'm testing just the copy part, using "copyfile file1 file2". This copies one file from one location to another. The problem is if the path is for example "w:\work stuff\temp\file1.jpg", then the result is max sees that path as "w:\work stuff emp\file1.jpg"
The "/t" is picked up as 3 spaces.
I could use dos commands, but then how do I deal with the UNC paths?
Some insight and possibly some examples will help a lot please for the browsing files and adding to a list to copying etc
