Maxscript needed?
  • Maxscript needed?
    Hi Forum,
    I currently encountered an interesting problem about selectioning specific objects in a scene (Max 6).
    For example:
    I have a scene where (for import reasons) a large number of primitive cylinders exist. All those cylinders share the same parameters (even materials) except one detail: A part of them is of a different radius then the others.
    As I want to delete those thicker ones and it makes no sense selecting them one by one (10.000 objects) I would need a selection filter that points those thicker cylinders out (the thickness is always the same among those thicker ones).
    I wonder if anybody encountered similar situations and what solution would be the best.
    Thanks in advance,
    Daniel
    ____________________
    www.formfest.de
    --select all objects to filter out
    x=10
    --radius to trigger
    filteredobjects=#()
    for i in selection do
    try (
    if i.radius >= x then append filteredobjects i
    catch()
    clearSelection()
    for i in filteredobjects do selectMore i
    --filtered objects should remain selected now
    Marc Lorenz
    ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
    www.marclorenz.com
    www.facebook.com/marclorenzvisualization
      as you're talking about imported geometry, i doubt they still have a radius property, so you might try it with absolute values
      first, select one of the big cylinders and type
      $.max - $.min
      into the script command line. You'll get something like f.ex.[63.5234,63.5234,150.222]
      The first value is the diameter, so if you want to select all cylinders bigger than a certain diameter threshold, you got to edit that value in the script. For sure you can measure out that value as well.
      Then select all cylinders and go.
      Code:
      bigones = #()
      diameter = 60 --parameter to edit
      a = i.max - i.min
      if a.x > diameter
      then append bigones i
      else()
      select bigones
      Hope this helps,
      Michael
      edit: for sure, the first value is only the diameter if the cylinders are straight up - else you gotta choose the appropriate one. When they're all rather randomly rotated, my script won't work as it only checks the bounding box in worldspace.
      This signature is only a temporary solution
        Thanks guys,
        I'll try that out.
        @sushidelic:
        Even imported they remain primitive cylinders, as they are vrml objects and 3dsmax knows to translate them to own native cylindres.
        www.formfest.de
