Windows 10 Pro just decided to update during a render
  • Windows 10 Pro just decided to update during a render
    I had heard horror stories of Windows 10 restarting during use, but generally they were the Home version.
    Just now however I was doing a render when bam, Windows 10 decides to install a "feature update" which took 45 minutes.
    Luckily this was 'after hours' and not an urgent crunch time render, or I would be actively hunting Microsoft managers to punch.
    I'm sure I'd set it not to do this in gpedit, however I've just read that this no longer works as it's been patched out of Pro since the 'anniversary update'. http://www.ghacks.net/2016/07/28/mic...indows-10-pro/
    Does anyone know a surefire way to stop this happening again? I can't believe this is actually a thing, but it is. Apparently now only users of Enterprise, Education and Server can control updates.
    i stopped and disabled "Windows Update" in services. Haven't been bothered since
      Since the Anniversary update, you can no longer disable it. It has happened to me several times. A couple on deadline projects that cause me to miss the deadline.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090
      • ​Windows 11 Pro
        yep its rubbish. if only there was a viable alternative.
        _______________________________________
        behance
        tumblr
        Linkedin
          WTF ??! no way to control Windows Update ?
          I didn't have this problem before and I hope to not have it !
          Anyway, it will be great to have a solution...
          (Sorry for my bad english)
            You can disable/defer updates by editing the group policy.
            Go to start menu, type edit group policy, click on app
            Go to computer configuration, administrative templates, windows components, windows update
            Select "configure automatic updates" and click edit policy setting. Switch it to "enabled" and set the option to "3 - Auto download and notify for install"
            We've done this on all our workstations and render nodes. Seems to be working so far.
            Check out my (rarely updated) blog @ http://macviz.blogspot.co.uk/
            www.robertslimbrick.com
            Cache nothing. Brute force everything.
              This is apparently no longer effective in Pro since the anniversary update. You can still set it, but it won't do anything.
                Hah, if that works that'd be perfect. Didn't think it'd be that easy.
                  Had the same issues,
                  Ended up using the active hours option, which I have set from 10pm to 10am. This means the pc's won't update during these hours which is handy for me as I often render finals overnight. During the day the pc's can update which I can keep track of, is usually only during testrenders anyway.
                  Other options gave too much hassle imo.
