Multiple soft body simulation
  • Multiple soft body simulation
    I've had various degrees of success in setting up simple soft body simulations in Max using different methods (mparticles, flex, cloth modifier...etc.) but I've recently tried to find a solution for simulating multiple soft bodies interacting with one another and I'm struggling.
    I realise that this is something that Houdini and Realflow can handle very well but before I accept defeat and buy/attempt to learn one of these, I thought I'd ask if anyone knows of a good method or plugin that would allow me to simulate large numbers of soft bodies inside 3ds Max?
    This is the sort of thing I'm after:
    https://vimeo.com/112199212
    https://vimeo.com/155232116
    Cheers!
    MDI Digital
    moonjam
    I'd think that thinking particles might be your best bet if you want to stay in max. But that is twice as expensive as a houdini indie license. (if you qualify for it)
    Other than that I am pretty sure I saw somebody did a similar effect with some pflow trickery but I don't remember exactly who it was.
    *edit*
    Nvm I found it: https://vimeo.com/6757009
    Maybe this helps.
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
      https://ephere.com/plugins/autodesk/max/lucid/
      I have no experience with that, but I just remember it had soft body sims.
      Would that work? Its for GPU though, so it has limitations I bet.
        Thanks!
        I hadn't seen Anselm's video before. He definitely knows his stuff, so I will take a look! I also completely forgot about thinking particles. It might just be that I can justify it for this project...
        As for Lucid, I tried the demo but it crashed every couple of minutes, so I don't think I can justify buying it just yet.
        Thanks again!
        MDI Digital
        moonjam
