removing colapsed vertex paint
  • removing colapsed vertex paint
    i have a object i painted with the vertex paint option applied, i colapsed it and now i want to remove it and pain another or just erase some areas, so far adding a new vertex paint option does not seem to work ontop of the mesh, only option i see is to really export out the mesh and reimport, anyone knows way to actually be able to remove a colapsed vertex paint?
    Architectural and Product Visualization at MITVIZ
    http://www.mitviz.com/
    http://mitviz.blogspot.com/
    http://www.flickr.com/photos/shawnmitford/
    i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
    Tools -> Channel Info. Select vertex channel (0), right click and hit clear. Then, collapse the modifier it added.
      wow, sounds so simple, will give it a try as soon as i get home, if this works man i will be sooo happy
        Should work, but if it doesn't please let me know.
        Best,
        AJ
          Best,
          AJ
          yes sir sure enough it did! thanks man! was pulling my hair out over this, i owe you one
            Glad to hear it! Best of luck on your project!
            AJ
              AJ
              thank you!
