MAX RLA file format
  • MAX RLA file format
    Hi!
    Does enyone know if there is some resolution or image aspect ratio
    limitations in RLA files? The image I'm trying to import to After Effects
    is 2756x5905. I get the following error: RLA data size does not
    match image size. Any help really appreciated!
    best regards,
    Mare
    I don´t know if there is limit.
    But you could try loading the picture to the max ramplayer
    (or any other program that supports rla) and
    check if it´s loading there. Maybe it´s an After Effects Issue...
