need a bit of info about Xfrog
  • need a bit of info about Xfrog
    Xfrog seems to get good reviews here, but i am a tad confused after looking at their site. They advertise a program 'xfrog 3.x, that will make trees and plants just liek speed tree, but they also have collection cd's that are for specific markets, US Trees, European trees etc etc.... now I would be interested in using the collection CD's for my trees but my question is do I need the xfrog program first installed, or are these collections just meshes of trees with their associated maps?
    any info is appreciated,
    Thanks,
    Tom
    Accept that some days you are the pigeon, and some days you are the statue.
    hi
    i am testing various tree plugins at the moment
    with xfrog you can have a max importer plugin that can import an xfrog file
    i assume that the cd s have trees saved as xfrog files in the same way that you have some trees that come with the xfrog library which means that you can import straight to max
    however the geometry that most of the standard ones i ve tried importing is quite high
    xfrog is very good if you want to generate your own trees or heavily modify the ones they supply
    you might wanna have a look at bionatics and especially easynat
    they do a special fro max 7 users for 50 plants ,anyones you want , for around 900 euros i think
    the good thing with easy nat is that you can create both high geometry or billboard trees depending on your needs
    the best thing to do is download demo versions for both and test them
    regards
    alkis
      i havent used an x-frog file in max for a while now but i remember it used to be slow in converting the file for render. I used to just use editable mesh versions of x-frog trees.
        thanks Guys,
        "I used to just use editable mesh versions of x-frog trees."
        ok are these the CD collections they sell?
        no plugins needed if I use these?
        thanks,
        Tom182
          thanks Guys,
          ...no plugins needed if I use these?
          thanks,
          Tom182
          The collection cd's come with an import plug-in. The models either come in as editable meshes or can be converted (I forget which and I can't check right now).
          Surreal Structures
          http://surrealstructures.com/blog
