backburner error!!
  • backburner error!!
    I'm trying to use backburner for a test animation but when I try to use it I get an error that says
    "Error creating 3ds max plugin instance for backburner"
    Manager and the servers all start correctly and show they are connected. But when I set it to net render and hit the render button I get that error and max closes until I close the error message and then it comes back up.
    The network works fine for DR in vray. I'm using UNC for the directories as well.
    I would really appreciate some help with this. MAX 7 and backburner 2.3 on all my machines.
    Tony
    its a problem in the local machine.. a registry setting with a wrong path i think.. Search for the error on the discreet board.. theres a fix there.
    Dave Buchhofer. // Vsaiwrk
      Thanks Dave. It was a registry path problem! Working great now, thanks.
      Tony
        hey guys, take care with backburner if you have computers with diferent open gl versions, it can also crash max. i spent almost a month trying to figure out what was my problem, after update my video board and get the same opengl version in both computers, it goes fine
        natal - brazil
          coudĀ“d someone help here..that got it fixed these days... same problem again with max2010...
          http://www.chaosgroup.com/forums/vbu...lugin+instance
          http://community.softimage.com/forum...nce/page-last/
          big thanks thomes
