Intersecting Faces
  • Intersecting Faces
    Is there a script somewhere that prevents intersecting faces/polys at render time?
    Hi rusteberg
    In the Vray Global Switches roll-out there is an option called "Secondary ray bias" If you set it to say 0.01 or 0.02 it will use a small bit of displacement at rendertime to help offset co-planar faces
      Thanks for the tip - I'll check it out!
