Maxscript help
  • Maxscript help
    Hi all,
    Does anyone know how to set all materials for an object to have the same materialID?
    I've been using $.material.effectsChannel = 5 etc, but this only works on single materials, not multi/subs.
    Thanks for any pointers!
    This seems to work and sets the MultiSub and its child materials to effectID 7
    Code:
                for MatID in selection do
                    if classof MatID.material == MultiMaterial then
                        MatID.material.effectsChannel = 7
                            for MatNum = 1 to MatID.material.materialList.count do
                                MatID.material.materialList[MatNum].effectsChannel = 7
    But throws up this error in the listener (which breaks the script after it has run)
    Code:
    -- Error occurred in anonymous codeblock; filename: ; position: 248; line: 8
    -- Unknown property: "effectsChannel" in undefined
    If I change out the MatID.material.materialList[MatNum] to read as the actual material number ie: [5], then I don't get the error.
    Any ideas?
      This should set the effects channel for materials and multimaterials:
      Code:
      fn setMaterialChannel m c = (
          if m != undefined do m.effectsChannel = c
          if classOf m == MultiMaterial do (
              for s in m.materialList do setMaterialChannel s c
      for o in selection do (
          setMaterialChannel o.material 5
