maxtreme6 for viz 2005
  • maxtreme6 for viz 2005
    anyone using this combo / know if it's possible...?
    when the going gets weird, the weird turn pro - hunter s. thompson
    i have no problems running it on a geforce4 with the softquadro hack.
    -oconv
      maxtreme6 doesnt work right on Max7 unfortuneately
        I'm using it on Viz 2005, but it seems like once you set up the options once, it won't let you go back into the Maxtreme settings at all even though it is your current display driver. Seems to work pretty good though.
        Tim Nelson
        timnelson3d.com
          timmatron, how did you install it?
          i get an error saying it won't install beacause i dont have 3dsmax installed...
            Hmm, I don't exactly remember. When you install it, does it ask you for the Max 6 directory? And then can't you just point it to the Viz directory instead?
            It's been a few months since I installed it, so I can't remember anymore. I don't remember there being any real trick to it though.
            Tim Nelson
            timnelson3d.com
              maybe the installer has changed...
              it doesn't even ask for a directory, just comes up with an error:
              the NVIDIA MAXtreme6 Setup could not detect 3DS MAX installation.
              Installation will be terminated.
              then quits...
                Maxtreme sucks in my experience, everytime they bring out a new version there is always something wrong with it, some display problem fast wireframe no edit poly handles, zbuffer display incorrect.....then you have to wait 6 months to get an updated installer for the latest version of Max. It's only good for very large scenes, when you have no other choice. I wouldn't buy a quadro based on Maxtreme scores because it's very unreliable software.
                Richard De Souza
                www.themanoeuvre.com
                  i think copying 3dsviz.exe and renaming it to 3dsmax.exe was the trick...
                    it sounds so simple that it just might work... i'll give it a try.
                    thanks.
                      tried it, but unfortunately it didn't work.
                      i think the installer probably checks the registry for max rather than just looking in the program folders...
                      oh well...
                        Man, I don't know what to tell you. I didn't have any version of Max installed on this machine & I was still able to install it for Viz.
                        If it's any consolation, I don't really think it's much better than Open GL anyways. That and the fact that you can't change it's settings is almost not worth it.
                        Who knows, maybe Maxtreme will be better supported in Viz 2006.
                        Tim Nelson
                        timnelson3d.com
                          yeah... i doubt it though.
                          i'm not really all that fussed anyway, just did a fresh install of viz and thought i'd give maxtreme another go.
                          i used to use maxtreme 4 with viz4 and found some of the features quite useful, but i can live without it.
                          thanks for all the help anyway!
