I'm trying to apply a Vector map -> illustrator file on an uwrapped object/template from max, but it doesn't scale correctly when applied to the object. Using a jpeg export from illustrator and going with a bitmap map on the object in question instead scales correctly. So there is something missing between the Vector Map and Unwrap Map process.
Is this even possible though? The reason I ask, is that there doesn't seem to be anything on the internet about it.
