Anybody having issues with the mouse lagging every few seconds? It is happening in both MAX and Photoshop. It's almost making working impossible. I updated my video driver, but it didn't solve anything. Even opening Windows Explorer takes about 10 seconds.
Microsoft Spring Update
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
Originally posted by stevesideas View PostI'm not sure if I had the same issue as you but I did notice that the mouse would pause at a consistent rate. I changed it to another USB port and it went away. Maybe this will help.Bobby Parker
phone: 2188206812
- Windows 11 Pro
It isn't really a mouse thing, everything is delayed. Pick something and wait 10 seconds, pick a command and wait 10 seconds... Open the layer manager and wait 10 seconds..! It just took me over a minute to Boolean a hole into a plane.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Totally removing the graphics driver using DDU worked for me.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Actually, it didn't work. I thought it did, but it persisted. I tried resetting my virtual memory, which now seems to have worked. I'll let you all know if it solved my issue.
Bobby Parker
phone: 2188206812
- Windows 11 Pro
if you have the latest gpu drivers rollback to the previous 2, the last two are crap and i have these issues are updating so i rolled backArchitectural and Product Visualization at MITVIZ
http://www.mitviz.com/
http://mitviz.blogspot.com/
http://www.flickr.com/photos/shawnmitford/
i7 5960@4 GHZm, 64 gigs Ram, Geforce gtx 970, Geforce RTX 2080 ti x2
Yeah, I have it downloaded, but didn't install it yet. Things seems to be working better by tweaking my virtual memory, although Windows Explorer is still acting up. I can right click a file to copy and the wheel will spin for more than a minute. This has happened before with a Microsoft update and they end up eventually pushing out an update that fixes it.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Bobby in your case you shoudl not need virtual memory at all you have plenty of un-utilized ram.
on mine i have 256 GB RAM and i dont use any virtual memory....and i hardly have these hick ups.
However i still have the random freezes when both of my XEONS are on full load and nothing helps there.
What i found, even if i change processors affinity and number of cores working, it checks back within few minutes to full usage - for whatever stupid reason.
Martin
http://www.pixelbox.cz
I Googled the problem I had and one of the solutions was turning off allowing Windows managing the virtual memory; it seemed to have worked. I set it to the recommended numbers.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostI Googled the problem I had and one of the solutions was turning off allowing Windows managing the virtual memory; it seemed to have worked. I set it to the recommended numbers.
1st thing I do with a new install is switch from auto to set the min (initial) and max virtual ram 4 times the amount of physical RAM
Kind Regards,
Morne
Hey Morne, as far as i ve read, with large amounts of Ram the virtual memory setting thing gets obsolete. It used to be 1.5x the amount of ram, but i my case that woudl have to be ober 400 GB of disk space at least.... something i am now willing to give up for windows especially when i have quite expensive nvme drive. Thats why i went to read about that a bit more atd found on tomshardware forums that its not really necesary with such high ram counts. The highest ram usage i had so far was 196 gb.Martin
