CPU Render as expected vs GPU
  • CPU Render as expected vs GPU
    Issue rendering image when using GPU as render engine. Using Vray for Sketchup 3.60.02. When using CPU as render engine, the render outputted looks as expected. However, when switching to GPU rendering, the render when finished is drastically different. Also, while GPU rendering, the output box shows what looks to be very similar to the CPU render, however once "threads completed" is done, it starts finalizing the image drastically different (see GPU render in process image). It is a very simple scene with only a rectangle set up as a grass texture (with bump map + using Vray fur).
    Any help, much appreciated.
    Forgot to include GPU render settings image.
      Please refer to the following post for a workaround:
      https://forums.chaosgroup.com/forum/...343#post988343
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
