Where can i set Material ID and Object ID?
  • Where can i set Material ID and Object ID?
    I use the Bloom effect and I want to use a Bloom mask. How can I set the Material ID and Object ID for use with the Bloom mask Material ID and Object ID?
    Where can I set the value of these parameters in this?
    Please help me
    Hello,
    Object ID can be assigned by right-clicking on an object in the SketchUp viewport. See https://docs.chaosgroup.com/display/...ContextSubmenu for more info.
    Material ID color is set in the Material Options section of each material's settings panel - https://docs.chaosgroup.com/display/...aterialOptions.
    Currently, there is no way to assign Material ID numbers manually. They are set alphabetically for each of Asset Editor's Material list entries at the time of render. This will be improved in the next major release.
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Originally posted by Peter.Chaushev View Post
      Hello,
      Kind regards,
      Peter
      Thank you
