Cant get Reflection Exit Color Working.
  • Cant get Reflection Exit Color Working.
    Hi Guys, so I'm bit confused about how would one setting the Reflection Exit Color right in maya with vraymtl, as you can see in this pic,it still shows black even if i set the exitColor to RedColor.
    I tried in both VrayNextBeta1 and very3sp6, cant get it to work
    and the weird thing is , the Refraction Exit Color works perfectly fine.
    thanks guys.
    That's something I suspect we broke at some point after 3.5.
    Is there a specific reason you need this to work?
    The 'exit' color was originally designed to save on render time when an object reflects too many other reflective objects and is far enough away from the camera that a simple color value would work instead of a texture. Otherwise, you just increase the reflection trace depth. It will never look good when the object is close to the camera.
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      yes indeed increase trace depth the way to go
      thanks
