Texture problem
  • Texture problem
    Hello all. I have a problem when I render diffuse texture. The diffuse texture looks different from original in the viewport. Is it a bug, or I doing something wrong?
    Okay, nobody knows why this is happening. I see there are people in the chaos group who write in the forum. Do you know why this happens?
      Are you using gpu?
      if so may be it could be that you need to change the resize option, by default is set to 512 px to avoid high ram usage.
      https://docs.chaosgroup.com/display/...ng-GPUTextures
        Yes Grigio18, I using GPU. Thank you for your help. Now everything working normally.
