Render Edges
  • Render Edges
    Are edges rendered possible? If so, what is the method?
    The exact render image I want to make is as seen in the picture.
      Hello,
      You can use an Edges texture in the material Diffuse slot. It will produce the desired without any additional adjustments.
      https://docs.chaosgroup.com/display/VRAYSKETCHUP/Edges
      Kind regards,
      Peter
      Peter Chaushev
      Let's keep in touch
        Thank you for your reply. Is Vray 2.0 also possible? I could not find the relevant option.
          No, Edges tex was introduced in V-Ray 3.4 for SketchUp.
          Kind regards,
          Peter
          Peter Chaushev
          Let's keep in touch
            OK, how can edge be applied on texture image like this? Click image for larger version
              This can be done (again in v3.6 only) by using a Mix (Map) texture (https://docs.chaosgroup.com/display/...ETCHUP/Mix+Map).
              The Edges texture needs to be slotted in the Top slot, and a Bitmap texture (containing the image file) in the Bottom one. The Mix Map slot should also use the same Edges texture but with white Edges Color and black Background Color.
              Kind regards,
              Peter
              Peter Chaushev
              Let's keep in touch
