Probably you have Motion Blur enabled in the settings of your renderer, but Phoenix FD has missing Velocity channel and renders with motion blur only in the Backup frames. Make sure that you have the Velocity channel exported in your Output rollout.
Hi. Georgi Zhekov thank you very much. I export Velocity channel the setting like photo1 but it still have the same problem. So I made the setting like photo 2 "Output Particles-->☑Export ☑Velocity" then the problem is solved. Is it the rignt way to solve?
