phoenix fd smoke works
  • phoenix fd smoke works
    why my simulation look like cloud ,too big ,I have tried increase resolution ,but it does not work and nither the outgoing velosity
    how can I get dust like smoke
    and I am very confused sometimes the smoke does not appear
    thanks~~
    this is my scene file
    my email is nice@nbyao.com
      anyone show me some tips ,A thousand thanks for your kindness^_^
      this is my test if its not show correctly ,
      I have upload to one drive
      https://1drv.ms/u/s!AvD7Vcm4GOGhp-9Fzc9naaNBw5Y25w Click image for larger version  Name:	12.png Views:	1 Size:	102.3 KB ID:	1012435
        Hi mate,
        go to Rendering rollout and then click Volumetric Options... There you'll find an Opacity rollout and Opacity curve. Tweaking the curve would make smoke opaque or transparent, so you'll be able to make it more visible or not.
          Originally posted by George Barzinski View Post
          Hi mate,
          emm,thank you very much ,but I didnt change the Opacity before , its just default value ,so I think it may be not that reason
            Your grid resolution indeed seems too low. Note that in the preview by default you have the Auto Reduction option that reduces the preview resolution so 3ds Max's viewport would not lag. If it has kicked in, your Reduction under the Preview rollout would be higher than 0 and the preview would show lower resolution than the render.
            Cheers!
              If you want to achieve a kind of a tire burnout,please check Car tire burnout example scene here:
              https://docs.chaosgroup.com/display/...Example+Scenes
