how to get jugged edges?
  • how to get jugged edges?
    as you can see in the picture the liquid is moving in a too much compact way, do you have any advice to get some jugged edges in order to make it more real?
    Hey,
    Can you share your path follow settings? If I could try to guess, maybe your Influence is tio high?
    Cheers!
      Outgoing velocity go from 10 to 50 in 150 frames
        Hmm, looks like you might be using a Phoenix version older than 3.11, and even than 3.04? You definitely have to first upgrade to a latest Phoenix, or even better - grab a latest nightly builds.
        Did reducing the influence lower to 0.5, 0.3 or 0.1 have any noticeable effect?
          thanks, i'm about to update my version right now
