VRay Instancer using PFlow Particle Age material maps
  • VRay Instancer using PFlow Particle Age material maps
    I have a PFlow system that uses particle age to fade down a particle over time. In the simplest case, fire embers that turn from orange to black.
    I have many of them and can't render them with VRay motion blur turned on, it crashes immediately. So instead, I use VRay instancer and it renders perfectly fine with motion blur but I can't obviously get particle age to work since Instancer is not aware of particle ages.
    Is there a solution to getting particle age to work?
    Or to check what I'm doing to get pflow with motion blur in vray...
    thanks!
    John Rouse - Lead VFX Guy
    http://www.johnrouse.net
    Los Angeles, California
