Can't Stop Rendering
  • Can't Stop Rendering
    Good afternoon
    There is a problem that repeats itself all the time.
    After I render once , or series of renderings successfully, suddenly the software hangs and does not continue .
    The program does not respond to clicking on the icon "Stop Render".
    There is no choice but to shut down SketchUp completely and often this does not help and I have to turn off the computer .
    Vray version is 3.60.02
    Operating System : Windows 7 Professional 64-bit SP1
    CPU : Intel Core i7 6700 @ 3.40GHz
    Graphics : NVIDIA GeForce GTX 1060 6GB
    Thanks in advance ,
    Ittai Frumkin
    Attached is a screen cut
    On the right you can see in the bottom line that Vray have stopped the rendering and is written " FINISHED"
    On the left, however, you see from the icon that Vray is still rendering !
    In this situation you can not do anything, only to get out of SketchUp and sometimes even to turn off the computer.
    Ittai Frumkin
      Can you try installing the latest V-Ray version ( 3.60.03 ) and tell me if you get the same error?
      Ivan Slavchev
      SysOps
      Chaos Group
        I am working all the time on the new version of 3.60.03 ( NOT on 3.60.02 which I wrote earlier with mistake )
        With all this the software gets stuck
        Attached is another screen cut from now ...
        As you see in the right side is written FINISHED ( I have stopped the rendering in the middle ) but the icon in the top left shows that it is running and pushing the icon is doing nothing and I can't render anymore unless I quit SkethUp .
