Vray and RPC
  • Vray and RPC
    How can I render RPC people with Vray?
    Vray renders both faces of the RPC, if I use standard scanline render then the RPC looks fine but with Vray you see both planes.
    To be honest it should be fine ... check you havent hit something in the rpc roll out ...
    Natty
    http://www.rendertime.co.uk
      Is it a problem with the RPC, when I have cast reflections selected it has a problem but if I un check this box then it is fine. How do I get the RPC to create reflections without the RPC looking wrong?
        you dont have to use that option.. vray will just reflect the rpc.
        Natty
          Thanks for the help.
          I have just tried adding a plane with a vraymap material for the reflection but the RPC's are not in the reflection.
          I'll try some different options and see if I can get it to work, if you have any other suggestions please let me know.
            Plane ... reflection (vray material ) and rpc .. nothing else.
            Natty
              natty thanks for all the help, it's working fine now.
                welcome.
                Natty
