GPU vs GPUs Question
  • GPU vs GPUs Question
    Not a GPU expert by any stretch. I'm using V-Ray for Sketchup 3.6... Are you better off having a higher end gpu, or two gpus of less power running SLI? I'm sure it depends on what cards, so how about this comparison:
    (Qty: 1) GeForce RTX 2070 Windforce 8GB
    or
    (Qty: 2) GeForce GTXs 1070 Windforce 8GB running SLI
    I know the dual 1070's would be a little more expensive. I have a $550-ish budget for a card, but could probably go to $700 if needed. I was just curious if you can throw a little more money at the problem, are you better getting the best GPU you can afford, or downshifting and getting dual cards?
    You can check these topics:
    https://forums.chaosgroup.com/forum/...nefit-from-sli
    https://forums.chaosgroup.com/forum/...80-ti-concerns
    also https://benchmark.chaosgroup.com/gpu
    Ivan Slavchev
    SysOps
    Chaos Group
