Ocean_sim_geometry stretch/streaks
  • Ocean_sim_geometry stretch/streaks
    Hello all,
    Came back to Phoenix Ocean sim after almost 2 years and I'm having some serious problems with getting it right. I get weird stretch/streaks at the front of a grid and it creates some sort of curve/wave and it doesn't blend right with the rest of a ocean.
    Also there are some problems with the foam on the edges of the grid as you can see on the image attached. I don't think birth volume is a solution here because I need long wake. For comparison I attached image with my old sim which was quite successful and none of the issues were present. I did find some info on this forum from other users with the same problems but it seems like there is no solution for this yet. Increasing SPF didn't help a lot and I've got Total Cells of 100 million already.
    I'm using the latest nightly from 28.01.2019
    Hope someone can help!
    Is it possible to roll back to ver 3.05? I guess that was version I was working 2 years ago with pretty much no problems.
    Regards
    Hey,
    I'm just making changes to the ocean border conditions in the nightlies. Hopefully in a few days there will be a nightly you can check. Will ping you when it's ready.
    Cheers!
      Ok, thanks Svetlin!
        Hey, grab a latest nightly and you should not have these issues anymore.
        Cheers!
