Weird light/ shadow effect with displacement
  • Weird light/ shadow effect with displacement
    Does anyone know what is causing the weird light/ shadow effect in my rendering? It seems to come from corners in my model, but I don't know why. For the bricks I used normal displacement.
    Thanks!
    you need to properly tessellate the geometry (can't be nsided) or else the displacement won't work.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Thanks for your reply. Can you be more specific? I applied the material to the surface and to the group.
        can you show the wireframe? it has to be equally tessellated with quads.
        Dmitry Vinnik
        ShowReel:
          Sorry for the late reply, I had a vacation.
          This is the wireframe . In the meanwhile I unchecked background environment (I use a Vray dome) and it seems the weird effect has gone for a large part.
            You need to draw extra lines..
              Thanks. I have to draw the line on the surface inside the group?
