Geometry Inside boat
  • Geometry Inside boat
    Hello!
    I have a problem with the geometry inside the hull that creates additional foam above the water, as you can see on the image below. Any idea how to solve this? I tried increasing the grid size to 230mln and up to 6 spf but no luck.
    Cheers
    Hmm, just make sure your hull geometry is set to Solid from its right click Phoenix properties and that it does not have any holes or inverted normals - this was the liquid should not be able to penetrate it and no particles would be born inside it.
    Cheers!
