mix liquids with different viscosities at the same time?
  • mix liquids with different viscosities at the same time?
    As of Phoenix FD 3.12, can mix liquids with different viscosities at the same time?
    For example mix water and honey
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    In fact, since version 3.10. This is referred to as "Variable Viscosity".
    You can also check what was new in each Phoenix version here: https://docs.chaosgroup.com/display/...on+Change+Logs
    Cheers!
      Can Liquid Dynamics (Surface Tension, Non-Newtonian, Wetting) be set for each Liquid source?
      oakcorp.net
      v-ray.jp
        Hey,
        Negative, for.now only the viscosity is variable, there is no variable surface tension or non-newtonian for now.
        Cheers!
          understood.
          Expect for the future
          Thank you.
          oakcorp.net
          v-ray.jp
