where is the Vray Properties?
  • where is the Vray Properties?
    i'm using Vray next 4.10.02 in 3ds max 2018.i found no Vray Properties in the Quads ,so i can't adjust the caustic in the objects or lights,why?how can i solve it?
    Click "V-Ray Menue Integration" in V-RayToolBar.
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
      it's solved,thank you.
        Beside what flat said, you can also run the
        Code:
        registervraymenus()
        command in MaxScript Listener
        Miroslav Ivanov
        Chaos Cosmos
          thank you,it's solved.
