Normal material object in front of toon material object - edges problem
  • Normal material object in front of toon material object - edges problem
    I we are getting weird effect. When we have a normal material objects (like white trees above) in front of toon material (wood on the back), normal material objects are getting edges as well. Why it so? Is there a solution to this problem?
    Sincerely,
    Zbieraj
    C.F. Møller Architects
    Aarhus, Denmark
    https://www.cfmoller.com/
    Hello,
    Thank you for reporting this. Kindly note that this is a known issue and unfortunately a temporary workaround cannot be recommended. Resolving all existing Toon material bugs and improving its functionality is high on our to-do list. We will keep you updated about its progress and any suggestions or ideas on how we can enhance the mtl Toon are welcome and will be considered.
    Kind regards,
    Natali
    Natali Velcheva
    V-Ray for SketchUp | V-Ray for Rhino | QA
    www.chaosgroup.com
