So its a standard VISMAT downloaded from ChaosGroup.com
Why isn't this material uploading?
Tags: None
Any material file (.vrmat / .vismat) created using V-Ray 2.0 or later should load fine.
Could you please tell the exact location of the file you have downloaded?
Kind regards,
PeterPeter Chaushev
Let's keep in touch
It appears the file you are attempting to load is a legacy type of V-Ray material, created using a version of V-Ray older than 2.0.
It is not recommended to use such materials! They may contain deprecated parameters and are not guaranteed to function properly.
If you wish to use them regardless, you can load them on your own accord by making the following adjustment to your V-Ray for Rhino installation:
1. Download the following archive: vrmatconvertdll.zip
2. Make sure Rhino is not currently running on your machine
3. Extract the file within named vrmatconvertdll.dll
4. Place vrmatconvertdll.dll in the following directory:
If you use Rhino 6: C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6
If you use Rhino 5: C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V5
This should make it possible to load legacy materials such as the one you currently possess. Once again, we do not recommend using them in your projects.
Please advise where you found
Originally posted by akashi1 View Postits a standard VISMAT downloaded from ChaosGroup.com
Kind regards,
PeterAttached FilesPeter Chaushev
Let's keep in touch
