I think your carpet needs a little tinkering tho. I would suggest you add a small black border around your displacement map, this will make things look alot neater. If you are using procedurals for the displacement, render that out to a large texture then add the black border in photoshop (or something similar)
Thanks, i was having some problem with the carpet i didnt know what to do with it I think Ill change the texture and the colours of the fabric. I was thinking in putting more detail in the exterior. (Thanks cinematic). You are right.
Any way, i must stop this work because I received another one.
Thanks every body im new in posting and your crits really helps and supports.
