SSS(skin) need help from masters please
  • SSS(skin) need help from masters please
    hi all ...please for 3ds max .
    i am having a problem with sss shader i am using vray 1.45.15 and when i use the transculant i can't control the places where sss is greater than other places and when i use it i get a very red light around the eye ...
    vray : 1- is the refract map must be black/white map or color one and IOR is 1.1 .
    2- is the reflect map must be black/white map or color one .
    3- what about the fog color what should i use .
    4- how mush thickness i should use .
    5- should i use shell modifier or not .
    6- what kind of light should i use the vray plane or default omni, spot, directional.
    7- should i use GL
    and about the eye should i use too spheres one is transparent and the inner one with reflect map and which part of the eye sould be more reflecty
    about the shadows what should i use .
    here is some skin mat the first one is mihi for v-ray
    http://www.FastImageHost.com/is.php?i=609&img=03al.jpg
    try a glossy map or a translucent map to drive the amount of SSS.
      Try this thread for a start:
      http://www.chaoticdimension.com/foru...pic.php?t=9240
      as for the thickness, it depends on the scale. If you decrease the thickness, the effect will be less deep. The easiest is to make a wedged shape and make some test renderings to determine the right thickness.
      I advise you to use false colors for testing, so you can better see the effect of each setting (transparent/translucent/fog)
      you can use any light, but without area shadows it will render faster
      what is GL?
        gl : global illumination
        what about shadows ...........
          SSS works only with GI enabled
          as for shadows, read my post again
          BTW: translucent color should not be white
            i did but i still can't find what lights or shadows you have used cause i am using max6 so i can't see the file pleeeeeeeeeease help me
            as i have seen in your matlib you dinn't use refract why how is that
            thanks Gijs for your help
              Save the image I posted, open it in max and pick the colors. you will see the refract color is not RGB 0 0 0
                thanks
                but what about the lights
                and the fdw/scater or..idont know what is it it is under the light multiplier
