Problems with Fog Colour Map
  • Problems with Fog Colour Map
    i have some troubles with fog color maps. somehow there are some problems with the curve at the bottom of the object.
    Can anyone help ?
    Best you send the scene to support@chaosgroup.com so we can take a look. Mention this thread in the e-mail as well.
      Hello,
      Please note that in V-Ray for SketchUp in order for the mapping to work properly there needs to be a texture in the diffuse slot.
      To resolve the issue in hand please do the following:
      - Open the Fog texture(V-Ray Asset Editor > Materials > the glass material > reflection > Fog Color) and under Texture Placement > Repeat set the value to 1(both for U and V)
      - Copy the fog texture to the diffuse and then disable it (there just needs to be a texture for the mapping to work)
      - Then press the Tri-Planar Projection(Fit) button Click image for larger version
ID:	1055189 in the tool bar.
      After that it should work as expected.
