HDRI map layout
  • HDRI map layout
    Hello all,
    A very basic question from a self-taught newbie: the 'layout' of my HDRI maps has changed and I have not been able to find a reason for this. As you can see in the attached image there is a wave in the map layout visible in the preview window, it is also evident when I try to compose an image to render. Initially the wave did not happen and I do not know what has changed. Any help much appreciated.
    Paul
    Maybe check the "UV Noise" section if the noise distortion is enabled there?
      Bingo, thank you Vlado!
