Morning all!
When we're working with client iterations only requiring render regions,our process after render completion (as the denoiser currently only denoises the region rather than the whole image) is to disable 'region render' in the vfb & then head over to the denoiser render element & hit update (not a massive chore but when you're repeating it multiple times it's starts to wear thin).
So... Have we either got access to the denoiser update function via maxscript or alternatively is there any plans to add an update button to the VFB UI? Better still, is if we could set it to denoise the entire frame on completion of a region.
Cheers
Cheers
