Rendering problems HELP!
  • Rendering problems HELP!
    I am currently rendering an architectural animation in blocks of 500 frames. I have generated a solution and then network rendered the frames with the solution, the first 100 frames render relatively quickly (4 mins), however, they then begin to gradually slow down over the course of the animation (50 mins). When I tested the solution rendering single frames at 100 frame intervals they all rendered quickly and in similar a time. The scene contains no complicated models or materials. We are using the RPC plug-in to populate the scene with trees, people, and cars. Does anyone know why the frames are slowing down over the course of the animation?
    Incremental add on your irradience map.
