How to render shadow only?
  • How to render shadow only?
    I have a CG road that I am overlaying on top of an image of a real road. I have an object passing over it that casts a shadow onto the road but I do not want to render the CG road, just the shadow on the CG road so that when I composite the animation onto the real footage the shadow appears on the real road.
    How do I render the shadow on the CG road but not the CG object itself?
    I have V-ray Next
    I think use vray object properties for your road. Make the road a matte-shadow object from within the vray object properties dialogue. Check matte object. Set alpha contribution to -1. Check Shadows
    I Need to do this only occasionally so some of my info may be off but I think that’s generally what you are asking for. Read the docs about vray matte-shadow Properties for more detail.
    There is now the same matte-shadow options from Vray material wrapper in vray5. I have not yet used it but you could look at that also.
    hope this may help
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
      Thank you very much! So easy if you know what to do.
