Image sequences with offset not rendering
  • Image sequences with offset not rendering
    I have a problem rendering image sequences when there is an offset applied. It is fine when rendering locally.
    They will simply not appear in the rendered frames.
    Here is a video of the problem being reproduced https://www.dropbox.com/s/2uufosvguz...50-35.mp4?dl=0
    I create a new scene from scratch, I then apply a small 15 frame sequence to a material, then apply it to a plane.
    I then offset the sequence by -5 frames. (It doesn't matter how much I offset, I still get the same problem)
    It renders fine locally, but when rendered to the cloud, it appears to be not read properly.
    I have tried changing to different frame padding as this results in error quite a lot of the time.
    I have updated License server and Vray to latest version. Maya is 2020, running on Windows 10
    Getting rid of the offset, sequence renders fine.
    Any help would be appreciated
