Vray 5 Camera Tilt problem
  • Vray 5 Camera Tilt problem
    Does anyone have this problem with camera tilt not matching the render? please see attatched image, am I missing something here?
    I'm no expert on this, but maybe scaling on the camera object itself?
    Daniel Schmidt - Developer of psd-manager
      Thanks Dan, I will try this, it was OK before the 5 upgrade
        I palyed around with the camera and I got a scene here where I can hold the mouse down on the Refresh Interactive View button (the green arrows) and then select the camera from the flyout menu (I think this menu is new) and then it matches the viewport. When it renders the active viewport it looks different.
          Thanks Dans, yeh same here renders is OK, interactive view stills different, strange I tried another old project and its OK
            Same here, Tilt/Shift doesn´t work correctly in the IPR after the update 1!
              Yep, reporting the same problem, Tilt/Shift goes wonky in IPR on 5.10
                Download the new V-Ray 5 here https://download.chaosgroup.com/?platform=49&product=47
                the camera Tilt/Shift problem is fixed in this newest version.
                Jackie Teh
                3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
                AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
                Website: https://www.sporadicstudio.com
                Email: info@sporadicstudio.com
                YouTube: https://www.youtube.com/c/SporadicStudio
