I was wondering if someone could clarify the differences and benefits of the V-Ray render engines available (CPU/CUDA/GPU).
I’ve noticed that only the CPU render engine allows certain options such as different “Primary Rays” settings under “Global Illumination”, or the “Ambient Occlusion Setting”. Why is that?
Is there a quality/time difference between the render engines?
Also, does V-Ray have adjustable settings for render/output dpi? There seems to be an adjustable setting for dpi on Rhino’s render tab under “Resolution and Quality”, but there are no such settings (at least when I’ve tried looking) in V-Ray’s asset editor. I am unsure if the dpi settings on Rhino’s render tab would change things in V-Ray, as I have read elsewhere that V-Ray always renders in 72 dpi. Can anyone confirm or elaborate on this?
