Vray light unit values went crazy!
  • Vray light unit values went crazy!
    hi,
    When adding basic Vray light planes on to my scene, and once I change the units from default to W,
    when changing the units to W the value automatically puts in a crazy long number, like 17498656.0 ....
    if I try and put in 'normal' values like 500 or 1300, it appears black, emitting no light, showing simply a black square in the render.
    what can be the cause for this?
    using Vray 5 with the latest update, for max 2022
    Hello,
    The conversion depends on the physical size of the V-Ray light - f.e if for some reason you are working in kilometers and the light has a size of 1x1km and you switch the light uints to W you get 65885796.0.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
