Vray and turbosmooth
  • Vray and turbosmooth
    Hi guys, out of curiosity why is it that when you activate render iters. in your turbosmooth modifier and set the normal iterations to 0, Vray will just ignore it.
    When you hit ipr render, it will still activate the turbosmooth in the viewport, it will still subdivide the mesh even if turbosmooth is set to 0 in the viewport. Why is that? At the moment this Render iters, which is very useful is useless.
    It only happens when using IPR. It's fine if you do a regular render, just fyi.
      hey thank you my firend
