Is there a way to find materials that render warnings refer to?
  • Is there a way to find materials that render warnings refer to?
    If I get a render warning that there's a shellac material or a raytrace material in the scene often it's just a map number which can be really tedious to find in large scenes, is there way to find error related materials and maps easily?
    I use Modifier Modifier Zorb to trace them. http://www.scriptspot.com/3ds-max/sc...-modifier-zorb
    A.
    www.digitaltwins.be
      Cheers, could you explain how that works? I had a look but it doesn't seem too clear unfortunately.
Name:	Screenshot 2021-06-29 205726.jpg
        Set the parameters from the materials tab to All and hidden to see all kinds of materials and maps used in your scene. You can right click them to select objects, delete materials/maps,....
        A.
        www.digitaltwins.be
          Ah OK, that looks like it might do the trick, thanks very much for the feedback!
