Bongo Animation
  • Bongo Animation
    Hi! Guys
    I'm using Bongo for animation. I've upgraded to Bongo 3.0. and now I can't render with V-Ray.
    See attachment
    Need help
    Thank you
    Hi StarUpJewelry,
    Apologies for the late reply.
    Just want to mention that since Bongo 3 is still work-in-progress, we are waiting for a final SDK release so support could be implemented.
    That being said, you can use the following script to run animations with Bongo 3 and V-Ray. The script will run the whole animation and keep in mind that you will need to manually set the frame range in the code.
    Hope this will be of help.
    Nikoleta Garkova | chaos.com
      Thanks Nikoleta Garkova
      I try to open the link, it doesn't work
        Hi StarUpJewelry,
        Do you get an error trying to access the link?
        I've attached a zip file with the script - anim_bongo3.zip
