Render preset without saving/changing composite layers
  • Render preset without saving/changing composite layers
    I trying to create render preset for test renders and then for final render. The last hurdle I think I have is, when I save my preset, and choose vray and the render elements, it seems to be saving the state of my composite layers.
    So if I use my preset on another scene, or even when switching between my test preset and final, it is changing the composite layers to the ones baked in the preset. Is there any way to ignore the composite layers when saving a render preset?
    On another note, is there a way to add a pre-render script without having to add the common tab to my preset? Basically I want to add a pre-render script to change to the composite source, without changing the max resolution.
    many thanks
