Differing render results.......single vs sequence
  • Differing render results.......single vs sequence
    Hello all. I have been working in Lumion for years, but I don't consider myself an expert.
    I have run into an issue that I have never experienced before. I spend little time on this forum, so if it was covered before, please point me to the post.
    There seems to be differences in result based on whether it is one single frame rendered versus the same frame rendered in a sequence. The same Lumion effects hold true for both.
    See attached. The lighter one is the still, the darker is the same frame in a rendered sequence.
    The project was modeled in Revit, imported into MAX for enhancement, and exported as an FBX.
    I added a series area lights to light the interior scene. Lumion 11.5.1 used.
    What causes the difference between single frame renders and rendering in sequence?
    Wrong forum. My apologies.
    Can Admin please delete.
